15 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
14 years ago --- Quote Start --- I was installing a FTDI interfaced USB relay board yesterday, for high-pressure gas flow control, and noticed that having installed as com8:, when I moved it to other usb ports it remained as com8: - a considerable improvement over what used to happen with usb com ports on a PC. --- Quote End --- This occurs if the USB device has a unique serial number. I use the FTDI tool FT_PROG to re-write the serial numbers on most devices. Eg., the USB-Blasters on my two Stratix IV GX development kits were the same, so I reprogrammed them with serial numbers S4GXDK00 and S4GXDK01. You can do the same with your FTDI cables. --- Quote Start --- I have been thinking in the meanwhile - you have really helped me with these discussions - now I have invested some months of work and also serious money in hiring a vhdl engineer to work on the state machine for this code, so I can not make this a habit, but would you like a (personal) copy of my interface firmware for the MorphicII or the FT2232H mini modules ? I will have to do some documentation. --- Quote End --- Sure, if you don't mind me critiquing the code :) I don't have the Morph-IC-II, so don't really care about the top-level code. But I'd be interested in your FTDI interface code. Here's how I coded an FTDI asynchronous interface; 1) Created a bus functional model of the FTDI interface 2) Created an Avalon-ST interface to the FTDI device, i.e., an FTDI-to-Avalon-ST bridge. 3) Created an Avalon-ST to Avalon-MM master component 4) Wired them together as an FTDI-to-Avalon-MM master. Using that interface, I can open a com port and write to an address via w 0 12345678 or read and receive a response r 0 12345678 I need to document that code too :) I've also implemented a UART-to-Avalon-ST bridge, which can then be connected to the Avalon-ST to Avalon-MM master, to enable RS232 command access. Again, its in need of documentation :) Cheers, Dave
