15 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
14 years ago --- Quote Start --- No, none at all. --- Quote End --- Ok, good. That just means I have a problem with my test machine. I can probably fix it by uninstalling all FTDI and Altera drivers, and then starting from scratch. --- Quote Start --- Only problem I had was, when uploading the program via the USB-Blaster, it left the system still reset by the FTDI interface. SO also had to also upload at least once by the FTDI interface. The fix should be simple, but I ran out of time then. --- Quote End --- On the Morph-IC, the reset signal for the FPGA was one of the FTDI outputs configured as a GPIO. You can use the ftd2xx DLL to setup the GPIOs, and then deassert the reset signal. Cheers, Dave
