15 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
14 years ago --- Quote Start --- Nice! .... While you were doing these tests, did you have any conflicts with the FTDI drivers and the USB-Blaster? .... Cheers, Dave --- Quote End --- No, none at all. Only problem I had was, when uploading the program via the USB-Blaster, it left the system still reset by the FTDI interface. SO also had to also upload at least once by the FTDI interface. The fix should be simple, but I ran out of time then.
