15 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
14 years agoThanks re tutorial link, Dave, I will follow it up.
The transfer from the FTDI chip is essentially a 60MHz byte-stream (=480 Mbit/s), clocked straight into fpga 16bit memory. Default USB transfer block size up to 64kByte (can be altered) . Video 2 shows 5MWord data vectors being binned into a 2kWord x 16bit buffer, at full rate. cheers, Beau
