15 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
15 years ago --- Quote Start --- Great. I haven't tried accessing a USB-Blaster under windows. Write some test code; a) Toggle TCK, while keeping all other bits high, so according to the protocol: 0011_1111 b /* bit mode, don't read-back, OE + TDI + CS# + CE# + TCK high */ 0011_1110 b /* drop TCK low */ So fill a write buffer with 3-bytes, i.e., 3Fh, 3Eh, 3Fh, and write it to the USB-Blaster. Probe the TCK pin and you will see a ~1us low pulse on TCK. Viola, you now have control of your USB-Blaster! Cheers, Dave --- Quote End --- Well yes and no ..... I have for a USB Blaster JTAG connector connected to the JTAG connectore on Morphic II, being the easiest for me to test : Orientation : Pins 2, 10 : Gnd Pin 4 : Vcc Then the JTAG connectors are bought out to Morhic IO connectors : Morphic II 0.1" connectors Altera USB Blaster (JTAG Mode) J3-23 JTAG_TDI JTAG Interface Pin 9 J3-24 JTAG_TMS JTAG Interface Pin 5 J4-23 JTAG_TDO JTAG Interface Pin 3 J4-24 JTAG_TCK JTAG Interface Pin 1 If Toggle Toggling Bit 0 TDI Pin 9, TMS Pin 5 If I write the 3Fh, 3Eh, 3Fh to the USB Blaster (and then call a Tx purge) Or as decimal and binary : 63 62 63 0 0 1 1 1 1 1 1 0 0 1 1 1 1 1 0 0 0 1 1 1 1 1 1 Then I have toggling : TDI Pin 9, TMS Pin 5, with TCK and TDO low. This is indeed a 1us low pulse. In fact it does not seem to matter which bit I toggle (other than the far left one), I get the same behaviour. Puzzled.
