15 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
15 years ago --- Quote Start --- I tried both the latest version of VMWare (workstation 7.1) and VirtualBox, and neither could capture the USB-Blaster to sniff from Linux in a VM. I installed Ubuntu 11.04 (Wubi - binary blob on the windows partition), and it works great. --- Quote End --- I stopped to update my copy of Cygwin, and so a web search, but could not see a version of Wireshark I could just try under Cygwin. --- Quote Start --- Apart from being able to access the USB Blaster through ftd2xx.dll, how do you want connect to the FPGA on the DE1/DE2 side? Did you notice, that DE1 and DE2 implement a second set of software JTAG lines between the embedded USB-Blaster CPLD and the FPGA? The interface is used in the DEx_USB_API demonstration for data transfer from and to the Control Panel application. Alternatively, you have communication options based on the VJTAG channel, e.g. the JTAG UART. --- Quote End --- This is where I am fairly ignorant - I have as yet never made use of JTAG or VJTAG .... I have been using an "8-bit port into block of registers" with a simple 4-byte address and read/write data protocol, via the FTDI chips, partly inherited from an early set of fpga modules, and partly extended by myself .... been using it for a number of years, for a range of fpga projects. I am trying to port this to the Morphic II - frustratingly is seems to sometimes work but mostly not, so I expect the state machine breaks when run faster. If we can build a bi-directional byte-stream vie the usb blaster to the FPGA, this could work on the DE1 as well ? This would be the first part of the project. The second would be to write a "block" transfer mode, to read the contents of a large block of memory. At this point I really need advice on how to build a 4 byte-stream interface from the PC to the DE1, ideally as fast as possible. Then I can immediately run quite a bit of code. Writing is : Write 4 bytes Reading is : Write 3 bytes (or 4), Read 1 byte. Not very efficient, but very flexible.
