15 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
15 years agoApart from being able to access the USB Blaster through ftd2xx.dll, how do you want connect to the FPGA on the DE1/DE2 side?
Did you notice, that DE1 and DE2 implement a second set of software JTAG lines between the embedded USB-Blaster CPLD and the FPGA? The interface is used in the DEx_USB_API demonstration for data transfer from and to the Control Panel application. Alternatively, you have communication options based on the VJTAG channel, e.g. the JTAG UART.
