15 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
15 years ago --- Quote Start --- I used to have wireshark for windows - did not realise it worked on the usb as well - perhaps just what I need for a related I/O problem I am having doing the same on a Morphic II board. --- Quote End --- Wireshark only supports USB sniffing under Linux. I tried both the latest version of VMWare (workstation 7.1) and VirtualBox, and neither could capture the USB-Blaster to sniff from Linux in a VM. I installed Ubuntu 11.04 (Wubi - binary blob on the windows partition), and it works great. I was also doing some testing with a Morph-IC (the older ACEX 1K device). Cheers, Dave
