15 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
15 years ago --- Quote Start --- Great! Huh? The FTDI drivers and DLL install fine under Windows. Its getting it to allow the DLL to access the USB-Blaster that I'm not sure how to do, given that the add VID/PID DLL call does not exist under Windows. --- Quote End --- Yes, that is sort of what I meant - yes the drivers and dll work great, but I can only load devices with different PIDs in XP, in Windows 7 I have to change the PIDS back to the standard value. But the ftdi dll seems to be able to access the usb blaster fine : ftlstndev 1 ftgetdescriptions USB-Blaster ftopen 0 FTDI USB device 0 opened, Handle : 40973760 40973760 But now I am not sure what will happen to any data I write to the handle .... ftclose 40973760 0 --- Quote Start --- A pretty simple solution is to use FT_PROG to capture the EEPROM settings from your USB-Blaster, and then erase the EEPROM. Then your USB-Blaster will appear as an FT245BM device, and you can access it using the DLLs directly (since the VID/PID will be FTDI). --- Quote End --- Scary, but that sounds good. I have had no problems using the EEPROM erase and write to-date. Do I then have just an 8-bit port in effect ? I will read up the info you pointed me to. Thanks!
