12 years agofail to compile after assigned the SFP_TX_P1 of SFP+ module (arria V gx dev kit)
I want to use the SFP+ module which converts electric signal to optical signal to transmit some data. I use the arria V gx dev kit. I assigned the data to pin PIN_W37 and select the i/o standa...
10 years ago --- Quote Start --- Are you using general purpose IOs or transceiver IOs? 1.5V PCML is only for transceiver IOs. --- Quote End --- Yes..I am using transceiver IOs.
