12 years agofail to compile after assigned the SFP_TX_P1 of SFP+ module (arria V gx dev kit)
I want to use the SFP+ module which converts electric signal to optical signal to transmit some data. I use the arria V gx dev kit. I assigned the data to pin PIN_W37 and select the i/o standa...
10 years ago --- Quote Start --- HI I was facing with the same issue. i have assigned clk,tx and rx differential pins in the same IO bank in pin planner and IO standard is 1.5V PCML while compiling its giving error as Error (175020): Illegal constraint of pin to the region (183, 42) to (183, 42): no valid locations in region Info (175028): The pin name: FO_RX_P[1] Error (184016): There were not enough differential input pin locations available (1 location affected) Info (175029): pin containing PIN_T1 Info (175015): The I/O pad is constrained to the location PIN_T1 due to: User Location Constraints (PIN_T1) Please help me out --- Quote End --- Are you using general purpose IOs or transceiver IOs? 1.5V PCML is only for transceiver IOs.
