12 years agofail to compile after assigned the SFP_TX_P1 of SFP+ module (arria V gx dev kit)
I want to use the SFP+ module which converts electric signal to optical signal to transmit some data. I use the arria V gx dev kit. I assigned the data to pin PIN_W37 and select the i/o standa...
11 years agoOh yes, now I remember that I had problems with the location of the clock pin that I was using for the transceiver clock. It had to be one that was in the same bank or at least a special location close to the SFP module.
