12 years agofail to compile after assigned the SFP_TX_P1 of SFP+ module (arria V gx dev kit)
I want to use the SFP+ module which converts electric signal to optical signal to transmit some data. I use the arria V gx dev kit. I assigned the data to pin PIN_W37 and select the i/o standa...
11 years agoThanks Eduardo, I think in my case the problem was solved by keeping all the pins constrained to one region. I had to move the LVDS to another connector. I had originally assumed that all of the LVDS RX pins brought to the headers were from the same bank but that was not the case. I wish the error would have been more clear, but I am past it at this point.
Regards, Lance
