12 years agofail to compile after assigned the SFP_TX_P1 of SFP+ module (arria V gx dev kit)
I want to use the SFP+ module which converts electric signal to optical signal to transmit some data. I use the arria V gx dev kit. I assigned the data to pin PIN_W37 and select the i/o standa...
11 years agoHi!
I don't remember exactly how I worked around this right now. If I remember correctly, that error can also be caused by a bad configuration of the transceiver block. I used the 1.5 V PCML I/O Standard for the serdes input and output pins and 2.5V for the rest. I also set the transmitter disable to 0 to activate the transmitter. Regards Eduardo
