12 years agofail to compile after assigned the SFP_TX_P1 of SFP+ module (arria V gx dev kit)
I want to use the SFP+ module which converts electric signal to optical signal to transmit some data. I use the arria V gx dev kit. I assigned the data to pin PIN_W37 and select the i/o standa...
11 years agoI'm curious if any of you solved this. I'm getting the same type of error that isn't giving me a lot to go on. This is related to some LVDS RX inputs I'm using with altlvds_RX on the Cyclone V (Bemicro CV eval board).
It seems like it is failing some "legality" check, but it isn't providing a lot of insight into what I can do about it. Searches haven't provided a lot of information. Thanks, Lance
