12 years agofail to compile after assigned the SFP_TX_P1 of SFP+ module (arria V gx dev kit)
I want to use the SFP+ module which converts electric signal to optical signal to transmit some data. I use the arria V gx dev kit. I assigned the data to pin PIN_W37 and select the i/o standa...
12 years agoThat's almost the same issue that I have at the moment. Actually in the pin assignment at the reference manual it says that the SFP pins have the 3.3V/LVTTL I/O Standard but I cannot choose it in Quartus. Any ideas?
