Factory reset on an Arria 10 GX DevKit revision E1.1
Hi Fade, thanks for your answer. Indeed I used the different FPGA images that come within the official software bundle to find the release of the board and after that I was able to perform a factory reset. This also restored the flash.
Just in case someone needs the schematics of this board: the official schematics do not match the board's design, I have attached the correct ones.- BHoej16 years ago
Hi. I know this is getting old, but I am in the exact similar situation. I am only able to download the package called: arria10_10ax115s3f45e2sge3_fpga_v15.1.2. This is made for the ES3, and is not compatible with my E1.1 board.
So, could you help me in what steps needs to be done (what differences/corrections between ES3 and ES1.1), or would you have the actual image files for ES1.1? I need to do a Factory Reset, as my card seems non functional at the moment.
I hope you see this comment :)
Best regards
Benjamin
