9 years agoFactory reset on an Arria 10 GX DevKit revision E1.1
Hi everyone, I would like to perform a factory reset on an early revision of an Arria 10 GX Development Kit. The board reads "revision E1.1" on the bottom part of the PCB -here are some pics- (ht...
9 years agoHi,
I do not have a quick answer, but what I would do is open the schematics from your board and the release on the web and compare the difference if they effect the Max V you mentioned. In the Production Package are also images for ES2 and ES3 devices. The POF did not change therefore I do not think that changed at all. I am not sure if the Kit uses Parallel Flash loader by default for configuring the FPGA. But it might be the case then you will need to replace the image in the Max V. You can use the different FPGA images from the Board Test System to find out which ES release you have. It should not work if the version does not fit. Cheers, fade
