Ethernet with DSP Dev. Kit Cyclone III (no NIOS)
I have the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). How can I use the Ethernet? In my altera > 80 > ip Directory I have triple_speed_ethernet. Will that work with this board? Or will I need additional IP-Cores? Will they also be shipped with my dev. kit? And are there IP-Cores for USB-Communication? Kind regards, Stefan__66 Replies
Sorry, I don't see anything wrong. Are you sure the PC is sending valid packets? The contrary would be very unlikely, but I don't see anything else...
is marvell 88e1111 hardware programmable or software?
I have a similar task. I would like to use the HSMC cards A/D ports to capture a Signal continuously and send it via ethernet to my PC.
Is that possible??? @stefan___: how did your project work out? Is it possible to send me some of the work you did? - Altera_Forum
@freelancer We are using DM648 on our customized board. The Marvell Alaska 88e1111 is used as PHY to establish communication b/w to nets to transmit TCP/IP packets. We have completed the Autonegotiation now working on packet send and receive. Please relate your project so that we can better communivate and share information.
Regards Danish - Altera_Forum
A base band radio frequency signal will be captured and connected to an A/D Port on the HSMC Mezzanine Data Conversion Board which is connected to the Port A of the Cyclone III 3C120 Development Board.
From there I want it to pass on the signal using the Marvell 88E1111 PHY to send it to a PC where I can store the data in a file. I don't have any experience on socket programming. I also havn't used a soft core (Nios II) before. There a very view examples about the RGMII which are acually explained. - Altera_Forum
@danish2010: how is your progress? are you finished yet?
I'm now using the triple speed ethernet design example in the NIOS II EDS installation directory and modifying it. Is there a way to get around the license for the TSE Megacore IP ??
