16 years agoEthernet with DSP Dev. Kit Cyclone III (no NIOS)
Hi, I have the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). How can I use the Ethernet? In my altera > 80 > ip Direct...
15 years agoA base band radio frequency signal will be captured and connected to an A/D Port on the HSMC Mezzanine Data Conversion Board which is connected to the Port A of the Cyclone III 3C120 Development Board.
From there I want it to pass on the signal using the Marvell 88E1111 PHY to send it to a PC where I can store the data in a file. I don't have any experience on socket programming. I also havn't used a soft core (Nios II) before. There a very view examples about the RGMII which are acually explained.
