12 years agoEthernet on Bemicro SDK
I'm trying to port the standard net example onto the BeMicroSDK which uses the DP83848C PHY. To keep it simple, I've disabled DHCP and hard-coded a Static IP for now. Everything seems to synth...
12 years ago --- Quote Start --- the problem could also be something like your host PC ethernet adapter had been configured to not auto-negotiate --- Quote End --- Not sure why, as all the settings match, but I changed computers and the auto-negotation now passes:
-->Your Ethernet MAC address is 00:07:ed:ff:cd:15
Static IP Address is 10.10.1.150
prepped 1 interface, initializing...
INFO : TSE MAC 0 found at address 0x04000000
INFO : PHY National DP83848C found at PHY address 0x17 of MAC Group
INFO : PHY - Automatically mapped to tse_mac_device
INFO : PHY - Restart Auto-Negotiation, checking PHY link...
INFO : PHY - Auto-Negotiation PASSED
INFO : PHY - Checking link...
INFO : PHY - Link established
INFO : PHY - Speed = 100, Duplex = Full
OK, x=3, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x04000203
RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 10.10.1.150
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
Created "web server" task (Prio: 4)
Web Server starting up
However, the same computer that's connected to the BeMicro, time's out when I enter its (static) ip address in the browser. I was thinking the problem has to do with the file system , since the NEEK boards store the webpage zip in flash, and on the BeMicro I'm just linking it as an object into ddr. However, putting a breakpoint in WSTask() where it waits a incomming connection on the listening socket, but it never gets there. Without any error message on the console, I'm not sure if it's on the logic/nios side or if the pc request isn't getting to it. Only the single wired NIC is connected to the BeMicro, with the PC TCP/IP setting set for a static IP 10.10.1.2, subnet 255.255.255.0, gateway of 10.10.1.1... the BeMicro set for a static IP of 10.10.1.150. Maybe WireShark can see for sure if there's traffic, but any obvious reason why there would be the webserver wouldn't work despite the mac/phy reporting auto-negotation and link established?
