12 years agoEthernet on Bemicro SDK
I'm trying to port the standard net example onto the BeMicroSDK which uses the DP83848C PHY. To keep it simple, I've disabled DHCP and hard-coded a Static IP for now. Everything seems to synth...
12 years agoRegarding cables, the problem could also be something like your host PC ethernet adapter had been configured to not auto-negotiate (for example, if you had previously set it to operate only in gigabit modes). This also is easy enough to confirm/deny with a switch.
Regarding packet storage, the software uses malloc() etc. to allocate packet storage space from the heap.
