12 years agoEthernet on Bemicro SDK
I'm trying to port the standard net example onto the BeMicroSDK which uses the DP83848C PHY. To keep it simple, I've disabled DHCP and hard-coded a Static IP for now. Everything seems to synth...
12 years agoI wanted to avoid a hub/switch + patch cable to the equation.. but perhaps it's a worthwhile test to eliminate the crossover-cable (I only have 1).
The descriptor storage uses on-chip ram, but how do the packets get placed in DDR while avoiding the Nios execution code? Since the linker script doesn't show the code to be bound to a certain area in DDR, isn't this dangerous?
