10 years agoEthernet interface not working on Max10 eval board with Linux
I have an Altera MAX10 10M50 Rev C Development Kit that want to setup under Linux. I have found the instructions below to set it up: https://rocketboards.org/foswiki/documentation/alteramax1010m50revcdevelopmentkitlinuxsetup It is working mostly: the board boots, and I can access the shell via the UART. The problem I have is I can't get the ethernet port to work. The PHY seems to be up (one LED lighted and the connection status is "up" as seen from the PC. I have tried forcing a static address with "ifconfig up" to no avail. I have attached the boot log for reference. Any help will be greatly appreciated. Best regards Loic1 Reply
Ok, my bad...
eth0 is connected to port A, and I was plugged in port B.... Problem solved.
