14 years agoEthernet Example Design on Cyclone III Dev Board (3C120F780)
Hi, I'm not able to get the Altera's Ethernet Example Design to work on the Cyclone III Dev. Board. I used the "Using the NicheStack TCP/IP Stack - Nios II Edition Tutorial".
PHY INFO...
14 years agoDisabling DHCP-Server in BSP-Editor->Software packages results in 3 errors:
Description Resource Path Location Type make: *** [niosII_Simple_Socket_Server_ohne_DHCP.elf] Error 1 niosII_Simple_Socket_Server_ohne_DHCP C/C++ Problem Description Resource Path Location Type undefined reference to `dhc_set_callback' iniche_init.c /niosII_Simple_Socket_Server_ohne_DHCP line 509 C/C++ Problem Description Resource Path Location Type undefined reference to `dhc_set_state' iniche_init.c /niosII_Simple_Socket_Server_ohne_DHCP line 483 C/C++ Problem
