14 years agoEthernet Example Design on Cyclone III Dev Board (3C120F780)
Hi, I'm not able to get the Altera's Ethernet Example Design to work on the Cyclone III Dev. Board. I used the "Using the NicheStack TCP/IP Stack - Nios II Edition Tutorial".
PHY INFO...
14 years ago --- Quote Start --- I set "dhcp=0" in iniche_init.c (line line 341) --- Quote End --- I'm not sure this assignment will really disable dhcp. You should disable it in bsp iNiche properties or remove the DHCP_CLIENT define inside ipport.h
