14 years agoEthernet Example Design on Cyclone III Dev Board (3C120F780)
Hi, I'm not able to get the Altera's Ethernet Example Design to work on the Cyclone III Dev. Board. I used the "Using the NicheStack TCP/IP Stack - Nios II Edition Tutorial".
PHY INFO...
14 years agoI marked the last two bytes of the IP and the MAC with "x", because the IP is in a public subnet.
I disabled DHCP and also tested the design in a private subnet (192.168.123.001 255.255.255.000) with no change.
