MNaga17's avatar
MNaga17
7 years ago
Error when executing testcases on TESTMAC for L1 Application
I compiled 5GNR software and trying to run testcases on TESTMAC appliacation for L1 Layer
The ouput of PHY console is exiting with an error messege as following:
The executing program located in /root/5G_Compilation/bin/nr5g/gnb/l1/l1app
pTablePath=/root/5G_Compilation/bin/nr5g/gnb/l1/table/
phy_prach_init_api:
ePreambleFormat = 0, config error!
phy_prach_init_params: ERROR ePreambleFormat [0] nL_RA [0] is not valid
Cleanup after [PID] 6554
rm: cannot remove ‘/mnt/huge/*’: No such file or directory
And one more error is
I am getting the below error as well in PHY console
5GNR Timer Mode
PHYDI-START[0]: Mode: 1, Count: 44, Period: 10, Numerology: 80
phydi_start phy_bbupool_reset: TODO
gnb_start_fpga: nTimerMode[1] gFpgaStarted[0]
probe FPGAs
init fpga fec CfgInfo failed
Error opening the dev node file 1
None FPGA found!
ICC Software version used:
icc --version
icc (ICC) 19.0.3.206 20190206
Copyright (C) 1985-2019 Intel Corporation. All rights reserved.
dpdk version : 18.08.
I will provide if any information needed in the follow up mail.
  • CheepinC_altera's avatar
    CheepinC_altera
    Hi, As I understand it, you seems to observe some issue when running a 5GNR software. To ensure we are on the same page, just would like to clarify with you on the following: 1. What is the specific FPGA device that you are using? 2. What is the Quartus version that you are using? 3. Are you using any FPGA devkit? If yes, mind share with me which devkit that you are using. 4. Sorry as I am not very clear about 5GNR software. Would you mind to further elaborate on it? Any reference to web would be helpful. 5. Mind share with me if you are using any ref design shared with by Intel? If yes, please feel free to share with me the design link as well as the contact person from Intel that you have been working with. Please let me know if there is any concern. Thank you. Best regards, Chee Pin
    • MNaga17's avatar
      MNaga17
      Thanks for the reply
      At this point of time we are not using any hardware, Not using FPGA Dev-kit and Quartus.
      Compiling 5GNR software on Intel Xeon High end Server and testing the L1 Application created by compiling the code.
      Please refer to 603577-flexran-5gnr-ref-solution-phy-software-doc-v18-12!
      Open pages.html, go to chapter 4. Compilation tools 4.1 Compilation. There are detailed compilation steps in this chapter and followed by testing.
      I am attaching Zip file of this or you can go to web.
      We are facing issues in testing the L1 layer after compilation.
      Contact person from intel : Li, Minjun <[email protected]>
      Bhavani
    CheepinC_altera
    Hi Bhavani, Thanks for your update and clarification. For your information, generally this Forum is used to address specific inquiries related to Intel FPGA. I understand that you seems to have inquiries related to 5GNR reference solution. It would be great if you could further consult Minjun on this. Sorry for the inconvenience. Please let me know if there is any concern. Thank you. Best regards, Chee Pin
    CheepinC_altera
    Hi Bhavani, Just would like to follow up with you are able to get in touch with Minjun? Please let me know if there is any concern. Thank you. Best regards, Chee Pin
    CheepinC_altera
    Hi, As I understand it, it has been some time since I last heard from you. I would set this case to closed at this moment. Feel free to file a new case if you have any further question related to this request. Thank you for your understanding. Best regards, Chee Pin
