error in ModelSim?
- 1 year ago
Inside the testbench myProject_tb_1.v, make sure the module name also myProject_tb_1.
Sheng
University Program VWF Simulations is legacy simulator. Probably some of the IP upgradation is not included in this legacy simulator. I would suggest to use the modelsim or questasim simulator.
Sheng
I chose University Program VWF because I'm not familiar with VHDL to write a testbench and because VWF provides a simple interactive method to generate waveforms. The single bits of a bus can be grouped and then a value can be defined for the group.
I had a look at modelsim and are missing a simple method to generate waveforms for buses. The design contains some 4bit buses as input which have to be defined for a testbench. The only graphical way (edit -> create/modify waveform -> ...) to generate waveforms I found is to define every single bit of the buses which is very tedious.
Do you know a better method?
