13 years agoError in creating flash files-**Error in creating intermediate files **
Hi Friends ,
I'm getting error while generating flash files using sof2flash command i used "sof2flash --input=TR4.sof --output=TR4_hw.flash --offset=0x00020000 --pfl --optionbit=0x18000 --programmingmode=FPP" then i'm seeing the following errors Info: ******************************************************************* Info: Running Quartus II 32-bit Convert_programming_file Info: Version 11.1 Build 173 11/01/2011 SJ Full Version Info: Copyright (C) 1991-2011 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, Altera MegaCore Function License Info: Agreement, or other applicable license agreement, including, Info: without limitation, that your use is for the sole purpose of Info: programming logic devices manufactured by Altera and sold by Info: Altera or its authorized distributors. Please refer to the Info: applicable agreement for further details. Info: Processing started: Mon May 27 17:32:49 2013 Info: Command: quartus_cpf -c tr4_hw.pof tr4_hw.hexout Info: Quartus II 32-bit Convert_programming_file was successful. 0 errors, 0 war nings Info: Peak virtual memory: 410 megabytes Info: Processing ended: Mon May 27 17:33:33 2013 Info: Elapsed time: 00:00:44 Info: Total CPU time (on all processors): 00:00:32 java.lang.nullpointerexceptionat com.altera.utilities.launcher.read(launcher.java:307)
at com.altera.utilities.launcher.read(launcher.java:362)
at com.altera.sof2flash.pflflashgenerator.converthextosrec(pflflashgener
ator.java:241)
at com.altera.sof2flash.pflflashgenerator.pflgen(pflflashgenerator.java:
37)
at com.altera.sof2flash.sof2flash.<init>(sof2flash.java:122)
at com.altera.sof2flash.sof2flash.main(sof2flash.java:77)
may 27, 2013 5:33:33 pm - (severe) sof2flash: error creating intermediate files,
exiting
And not able to generate flash files .. Please friends help me out ..I'm using quartusII 11.1 & Nios II 11.1 EDS , windows 7 32 bit OS.. Thanks & Regards, Rohit
Found elsewhere - must run from Nios cmd shell. So much for easy integration with make
hi ,
Have you ever solved this , because i have this message too : Error: Error code: 3 for command: sof2flash --input="C:/altera/13.1/projects/My_System_time_limited.sof" --output="C:/altera/13.1/projects/flash/My_System_time_limited_CFI_Flash.flash" --offset=0x0 --verbose thanks in advance , - Altera_Forum
Me too. ~SysTom
