14 years agoError: Differential I/O input pin clkin_125 is assigned to a non differential locati
Hello, I am using Quartus II v10.1 SP1 to compile for an Arria II GX (Altera ARRIA II GX Dev Board). I am trying to use the external differential clock in but I get the following error: ...
14 years agoDid you check if it's solved in Quartus V11? Otherwise you should contact Altera support.
I don't no if the solution told in the support note may be suitable for your design.
