14 years agoerror CONF_DONE pin failed to go high : cyclone 4 evalboard
hi i am using the Cyclone IV GX FPGA Development Board. it has worked fine for the last few months but now when i try to download the sof file on the FPGA the prosses go to near 90% then i have th...
14 years agoI've seen this kind of thing before. If you see the config done light blink momentarily, are there outputs that, once configured, are driving a short? Or causing the supply to droop? Check the all the supply voltages right at the moment that you see config done blink. I bet one of them is drooping, causing the FPGA to reset and look for another configuration.
