18 years agoError: Can't access JTAG chain Error: Operation failed
Dear all, i have a custom board, with stratix II, and Cyclone II, till today i dont have any problem in downloading code, and debug with JTAG port, but today i got "Error: Can't acces...
17 years ago --- Quote Start --- The power supply connection to your board might not be proper configured. The connection which comes the voltage regulator (+5v G -5V) has to be connected in a proper manner. Check them out again. --- Quote End --- I checked this, I found the net TCK to ground is about 80 ohm, whereas other nets are all about 10k. The problem is similar with below: http://www.alteraforum.com/forum/showthread.php?t=6340&highlight=jtag
