ABoni12
6 years agoError (209025): Can't recognize silicon ID for device 2.
I am trying to program a .jic into de DE10-Nano board (5CSEBA6U23I7). I am following the exact steps on the DE10-Nano User Manual, Chapte 8 "Programming the EPCS device". I am using the original USB ...
YuanLi_S_Intel
6 years agoHi Aldo,
It might be due to several reason.
https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm#msgs/msgs/epgme_device_siid_error.htm
Can you remove the Cyclone V HPS in the programmer and try to program again?
THank You.
- ABoni126 years ago
If I remove the HPS from the chain in the Programmer the progress bar fails inmmediately at 0%, giving me this error:
Error (209031): Device chain in Chain Description File does not match physical device chain -- expected 1 device(s) but found 2 device(s).
Anyway, I solved it, converting my .sof file selecting the serial device as EPCS64 (opposed to the EPCS128, as the manual said). That way I programmed it without probem. And all of it because the user manual had an error, yikes. Anyway, thanks!
