ywang161
7 years agoError (18108): Can't place multiple pins assigned to pin location Pin_XXX in Quartus 18.1.2 for a partial reconfig design
Hello, I met this error while trying to fitter my partial reconfig design with Quartus: Error (18108): Can't place multiple pins assigned to pin location Pin_AV25 (IOPAD_X233_Y12_N61)
Info (18...
LVEZI
7 years agoStill no answer from Intel...
I created a very simple testcase based on blinking_led example (which I use to try root partitioning as described in UG-20135 https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-block-based-design.pdf ).
In this testcase, there is no partial reconfiguration, only a partition for u_blinking_led instance.
- Run it as is will lead to Quartus error message.
- Comment out lines 27 to 37 relative to partition will remove this error message
I hope that this testcase will help Intel support team finding the source of our problem.
