ywang161
7 years agoError (18108): Can't place multiple pins assigned to pin location Pin_XXX in Quartus 18.1.2 for a partial reconfig design
Hello, I met this error while trying to fitter my partial reconfig design with Quartus: Error (18108): Can't place multiple pins assigned to pin location Pin_AV25 (IOPAD_X233_Y12_N61)
Info (18...
Kay
7 years agoHi,
1. Does design use PR?
2. If so, how are partial bitstream transported to the FPGA in user mode.
I could not find answers from the design.
- ywang1617 years ago
HI,
1.Yes the design uses PR. You can find this line in the tcl script:
set_instance_assignment -name PARTIAL_RECONFIGURATION_PARTITION ON -to counter_0
2.Due to the problem in fitter, I'm not able to generate a partial bitstream. However it is supposed to be transported to FPGA through the PR Controller IP with Avalon MM interface.
