DTruj3
7 years agoError 171172 Detected conflicting assignments
Error (171173): Node led[1] from partition Top cannot preserve previous placement at PIN A23 and honor the location assignment to PIN AK29. I'm using the Cyclone V GT Dev Kit. In the Pin Planner I...
- 7 years ago
After changing the pin/node location, perform Project-> Clean Project & then Start Compilation.
let me know how it works for you.
Vicky
DTruj3
7 years ago**UPDATE**
Apparently the top level design file has to be updated and Quartus does not update on recompile. I had to remove pin assignments by clicking on "Assignments" then "Remove Assignments" check "Pin, Location & Routing Assignments" then click "OK." Now in the Pin Planner reassign the node locations to the appropriate pins and recompile. The Error should go away.
