Error (17045): Input port I of I/O input buffer primitive |emif_0| .. |gen_mem_alert_n.inst[0].b|no_oct.ibuf is not connected
continue ..
in << External Memory Interface Handbook Volume 2: DesignGuidelines。pdf >>
- 7.4.3.2. Arria 10 EMIF IP DDR4 Parameters: Memory
there mentions as below: " Enable ALERT#/PAR pins - MEM_DDR4_ALERT_PAR_EN " which describes as following- " .. Allows address/command calibration, which may provide better margins on the address/command bus. .
The parity pin is a dedicated pin in the address/command bank, but the alert_n pin can be placed in any bank that spans the memory interface. You should explicitly choose the location of the alert_n pin and place it in the address/command bank.
Could I disable this " Enable ALERT#/PAR pins " in Arria 10 SOC ? If it's mandatory pin, how should I assign pin for it (alert_n) ? Thanks great for any help.
/jet
- BoonT_Intel5 years ago
By right you will see a RZQ pin in the IP top level file. You need to export this pon to top level and assign with an input pin.
