Error 16045: Instance "auto_fab_0|alt_sld_fab_0" instantiated undefined entity
- 5 years ago
We found the issue. The issue is caused by the update of Digital Guardian software tool on our Linux server. The new version of the tool somehow blocks certain functionality of Quartus, so certain IP files cannot be retrieved. Reverting to a previous version of the Digital Guardian solved the problem.
Thank you all for the help.
Regards, JQ
Did you try enabling Signal Tap or some other debugging tool? That entity gets instantiated when you use a debugging tool (sld = system level debug) that uses JTAG access for its use. Perhaps you accidentally enabled a tool and didn't configure it. Check the project settings to make sure Signal Tap is disabled.
It looks like you're using the golden hardware reference design (from Rocketboards, so you could also just download a clean copy of the design and recompile it from scratch.
