mho12's avatar
mho12
6 years ago
Error (10822): HDL error at triangular_carrier.vhd(21): couldn't implement registers for assignments on this clock edge
THERE have some error of my code
but i don't know how to slove this problem
can anyone help me to correct my code
thank you so much !
this is the errror message i had:
this is my code:
entity triangular_carrier is
architecture Behavioral of triangular_carrier is
signal x,y:INTEGER:=0;
begin
process(clk,Ts)
begin
case x is
when 0 =>if (clk'event and clk='1') then <---- there is my error occured
if y/=(Ts/2)then carrier <=y+1; y<=y+1;
else x<=1;carrier<=y-1;y<=y-1;
end if;
end if;
when 1 =>if (clk'event and clk='1') then
if y/=0then carrier <=y-1; y<=y-1;
else x<=0;carrier <=y+1; y<=y+1;
end if ;
end if;
when others=>null;
end case;
end process;
end Behavioral;
  • SreekumarR_G_Intel's avatar
    SreekumarR_G_Intel
    Hello Mark , In the HDL , every statement /code you write it will be good to make sure what hardware it can be realized or infer too. In most of the case synthesis tool behave very similar. For example lets take the above RTL,Case statement usually realized hardware as multiplexer ,..Now question is how you can implement multiplexer with synchronous logic, which is not possible right ?. that is why tool giving a statement " Cant implement the register logic(clocked logic) on this assignment" make sense? I would modify your code as below , if(rising_edge (clk) and clk = 1 ) then Case x is when 0 => when 1 => etc... Thank you , Regards, Sree
    • mho12's avatar
      mho12
      i revised the code as you teach me
      but i have this error message below:
      Error (10500): VHDL syntax error at triangular_carrier.vhd(33) near text "process"; expecting "if"
      there is the code i revised :
      begin
      process(clk,Ts)
      begin
      case x is
      when 0 =>
      end if;
      when 1 =>
      if y/=0 then carrier <=y-1; y<=y-1;
      end if ;
      when others=>null;
      end case;
      end process;
      end Behavioral;
      would you tell me where am i wrong
      thank you so much
    • mho12's avatar
      mho12
      or can i change the code like this
      is this same meaning of my code?
      begin
      process(clk,Ts)
      begin
      case x is
      when 0 =>if (clk='1') then
      end if;
      end if;
      when 1 =>if (clk='1') then
      end if ;
      end if;
      when others=>null;
      end case;
      end process;
      end Behavioral;
    SreekumarR_G_Intel
    Hello Mark,
    i am not sure about above code ..it looks same to my previous one ? ..can I ask what you trying to implement ? If you give me detail info I can try to help you out ?
    Thank you ,
    Sree
  • mho12's avatar
    mho12
    when i foolow your steps then revise my code as you teach
    it will have this error message :
    And this is the code which i revised
    begin
    process(clk,Ts)
    begin
    case x is
    when 0 =>
    end if;
    when 1 =>
    end if ;
    when others=>null;
    end case;
    end process;
    end Behavioral;
    SreekumarR_G_Intel
    Hello Mark,
    Here is the modified code ,
    you added the if condition for clk, but didnt add the end if .If it is not confidential ,and let me know what logic you plan to implement i cna help you out if i can ?
    begin
    process(clk,Ts)
    begin
    case x is
    when 0 =>
    if y/=(Ts/2)then
    else
    x<=1;
    carrier<=y-1;
    y<=y-1;
    end if;
    when 1 =>
    if y/=0 then
    else
    x<=0;
    carrier <=y+1;
    y<=y+1;
    end if ;
    when others=>null;
    end case;
    end if; -- Endif here misisng.
    end process;
    end Behavioral;
    Thank you ,
    regards,
    Sree
    SreekumarR_G_Intel
    Hello Mark, Can you let me know any further question on this topic , if not can you kindly close the case ? Thank you, Regards, Sree
