EPM7128E read and programming
- 6 years ago
There is no way in any practical sense to bypass the security fuse to allow reading the device program.
The whole point of the security fuse is to make reading the device program impossible.
You need to either find the original source/program code, or try and reverse engineer the device.
There are current production devices that can replace the EPM7128E (like the EPM7128S from Intel or the ATF1508ASV from Microchip/Atmel) but you need the source code (best) or program POF file to do it.
Per the Max Loader software (I am using v6.1h on my system) adapter PA84-48F is not the correct one to use for the EPM7128E device. You need adapter PA7128/E-84LC instead. Contact EEtools directly.
PA84-48F:
Vcc pin:22,38,64,73, Gnd pin:8,16,27,42,49 for Xilinx XC9572 PLCC84
PA7128/E-84LC:
Vcc pin:3,13,26,38,43,53,66,78, Gnd pin:7,19,32,42,47,59,72,82 for Altera EPM7128E PLCC84
