HGM_Indra's avatar
HGM_Indra
2 years ago
EPM7064STC100-10
Hello, I am doing some tests with the EPM7064STC100-10N device. I can program and verify independently, but if I check both checkboxes at the same time, the verification fails. What could be happening? If I test the board in the system, it works correctly.
  • babycom's avatar
    babycom
    EPM7064STC100-10 is Eol,If you really need it, I can send you the website our engineers often use to find alternatives, you can go and look for it,wsapp:+85265837594
  • NazrulNaim_Intel's avatar
    NazrulNaim_Intel
    We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
    Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
    We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
    NazrulNaim_Intel
    • HGM_Indra's avatar
      HGM_Indra
      I can wait, no problem, whenever you can. Thank you for your help.
    NazrulNaim_Intel
    Nazrul Naim
      HGM_Indra
      Thank you for your support, but your response did not resolve my issue. However, I managed to solve it by performing the programming first and then the verification in two separate steps.
