speranskyanton's avatar
speranskyanton
1 year ago
EPM3064ATC100-10N
Hello!
Could you please clarify — the component EPM3064ATC100-10N was discontinued in 2018, but we have received chips with a date code of 2107.
Was production of this part extended, or how is it possible that chips marked with such a recent date code exist if the part was discontinued?
Thank you!
  • speranskyanton's avatar
    speranskyanton
    Hello!
    The components were purchased from an authorized distributor.
    Could you please confirm whether the EPM3064ATC100-10N has been fully discontinued, or is it still being produced for internal or limited market use — which might explain why it can appear with a date code newer than the official end-of-life date?
    Thank you!
  • Hi,
    Can you provide the top marking photo of the device?
    Aiman
      speranskyanton
      Hello!
      I’ve attached a photo of the marking and the label.
      Thank you!
  • Hi,
    Since the device is EOL long time ago, Altera no longer produce the device.
    You may check with the distributor regarding the device purchased.
    As the device is EOL, we no longer provide further support for this device as we have limited information for the EOL device.
    Aiman
