13 years agoEPCS flash problem @ DE0-Nano board
Hello , may be , I have posted my problem in the wrong section, sorry. I have 2 DE0-Nano boards. One is working fine, the the other makes problems, only when I try to flash my sof+elf desi...
13 years agoHi Reinhard,
--- Quote Start --- I checked the notes from the Spansion dokument. For me, there was nothing special news included. The problem is still the same and I agree, it seems to be that this problem is related to the Spansion EPCS-16 chip integrated on some DE0-Nano boards. --- Quote End --- This is something that you can figure out yourself fairly easily. 1) Create a Qsys system according to this tutorial: http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial 2) Connect the PIO component to the Flash pins 3) Write some Tcl to toggle the SPI signals to the serial flash, write routines to read the serial number, manufacturer details, and read and write flash. That will tell you whether or not the flash is actually working. If it is, then its a problem with the Altera tools. Cheers, Dave
