TeresaM
5 years agoEOL = EPM570F100C4N?
EPM570F100C4N is this part EOL? or removed per PDN2041 Rev 2.0?
- NurAiman_M_Intel
Per PDN 2041 Revision 2.0, this revision 2.0.0 is an update to rev 1.0.0 with the purpose to remove MAX II (including MAX II G & MAX II Z) from PDN2041. Intel’s current estimate is that MAX II products will be reviewed for EOL in 2024.
Hence MAX II device family is still available and orderable as it will only be reviewed for EOL in 2024 and not in current time.
Aiman
- NurAiman_M_Intel
Since there is not update on this case, I will proceed to close this case. If you need further support, kindly open a new case.
Thank you.
Aiman
