12 years ago
Encrypted rbf loading on Stratix IV
I have a Stratix IV on a a Terasic TR4 development kit.
I'm trying to load an encrypted bitstream on the stratix IV.
I'm already able to load an encrypted bitstream using FPP in Quartus II:
- program the stratix IV with a Parallel Flash loader
- load the pof directly in the flash
- program the key .ekp
Then at reset, the bitstream is decrypted and programs the Stratix IV.
But it has 2 main drawbacks : It's very slow and I want to have a command line solution (preferably with a .rbf file)
Would you have a better solution ? Is a direct loading from USB blaster possible ?
Do you know the related command line ?
Thanks for your help
    Hi again :)
    I've tried to use the Passive Serial loading using the mblaster tool.
    This seems to allow the loading of an encrypted bistream. I put the MSEL1 to 1 on the board, the cable is well detected by the software. At the end of the loading (on , the tool says the configuration is loaded successfully but the configuration does not run on the fpga ... any clue ?
    I have another question:
    - even if it's very slow, I dit use the PFL loading http://www.altera.com/literature/an/an478.pdf which works
    I'd like to script it but I'm not able to find how to "attach a flash device" with a pof file in quartus_pgm
    Where could I find the way to do that ?
    I did read altera documentation and it seems to be possible to load encrypted design in Passive serial mode (AN556).
    But I can't find how to do that using my TR4 board !
    Is it possible ?
    Should I use the USB Blaster ?
    How could I do that ?
