8 years agoEMIF on Stratix 10 Dev Kit miss board file
Hi all i'm working on EMIF for stratix 10 Dev KIT while generating the IP i can't find my board listed in the presets how can i add it ? if i can't what should i do ? Thanks
8 years agoHi ,
--- Quote Start --- For Daughter cards refer the following link, https://www.altera.com/products/boards_and_kits/daughter-cards.html --- Quote End --- there are no memory daughter cards for stratix 10 --- Quote Start --- Have you installed the drivers, if not, Refer following link & install before using it, https://www.altera.com/support/support-resources/download/drivers/dri-index.html https://www.youtube.com/watch?v=wjwkdznh1py --- Quote End --- and i already installed the driver and it is working correctly , i'm using it to download the bit stream so same problems thanks
