8 years agoEMIF on Stratix 10 Dev Kit miss board file
Hi all i'm working on EMIF for stratix 10 Dev KIT while generating the IP i can't find my board listed in the presets how can i add it ? if i can't what should i do ? Thanks
8 years agoHi,
--- Quote Start --- i have already downloaded the package and tried generating several example designs and i always get calibration failed and i can't "create memory interface connection" in the EMIF Toolkit , so i can't even debug my design --- Quote End --- Refer the User guide, https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug-20120.pdf For Daughter cards refer the following link, https://www.altera.com/products/boards_and_kits/daughter-cards.html --- Quote Start --- i have also tested the examples in the package after downloading the bit stream , in the ISSP i have calibration fail and i tried to run Board Test System (bts) but the gui can't detect the jtag cable --- Quote End --- Have you installed the drivers, if not, Refer following link & install before using it, https://www.altera.com/support/support-resources/download/drivers/dri-index.html https://www.youtube.com/watch?v=wjwkdznh1py Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)
