13 years agoDUMMY Question
Hello folks. Total newbie here. This is probably going to be the dumbest question of all times, but as I need the answer, I figured, it would be even dumber not to ask. :p The question is...
13 years agoHello, guys.
Thank you for your fast response to the question. You're very kind. Yes, I was confused about Verilog and VHDL. Thanks for the clarification. But well, that's something that won't arise once I'm actually working in some project. I currently work with small audio and MIDI projects for the classroom, for which the microcontrollers are just fine. On the other hand, I've been thinking about the implementation of real-time FIR filters and other stuff, for which I think CPLD's could be far better. Nevertheless, I won't go as far as working with FPGA's for the moment. I was thinking about Max II or MaxV to begin. So, if I'm understanding well, I just get, say, the MAXII or MAXV starter kit and do my thing. Next, I just buy some chips and assemble the project with them, while they are still "empty". Once the thing is fully assembled, I just use a JTAG interface to program the CPLD's IN PLACE. If that's correct, then I'd like to know if there's a special thing that I should use for this last step. Also, and I know, off the subject, do you have any ideas on how to use this chips in projects without having to buy or rent expensive SMT equipment? Thanks a lot, folks. :)
