HUl_H
6 years agoDoes MAX10 FPGA supports Active/Passive Serial/Parallel configuration modes?
I want to program my MAX10 FPGA using another master FPGA or microcontroller. Does Max10 supports this configuration scheme?
NurAiman_M_Intel
6 years agoHi,
You can use the PFL IP core in Intel MAX® devices (Intel MAX 10, MAX II, and MAX V devices) or all other FPGAs to program flash memory devices efficiently through the JTAG interface and to control configuration from the flash memory device to the Intel FPGA.
Kindly refer to PFL IP userguide:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
Thank you.
Aiman
